I have this L40SX that appears dead. The display and the small display indicators are the only signs of life, the display backlight turns on and I can control the brightness, but that's all.
The rest of the machine looks dead, no chips gets warm, no sound, nothing.
I'm using a modern power supply rated at 15V.
I've removed all the batteries inside, I've noticed some corrosion on the battery terminals in the pcb, but doesn't look bad.
Also I see that some capacitors have leaked, but I see no traces damaged.
I've noticed this component marked "SOC 5A" that looks like a fuse (check pic attached). Is it a fuse? because it doesn't have continuity on my multimeter.
Will this machine power on without any of the batteries installed?
Any help will be appreciated.
