lsi11al
Taking the following instructions from the TU58FS site I tried to create rt11v53.tu58. After booting dd0: I tried to exit but got message UCL-F-File not found SY:UCL.DAT. Consequently rt11v53.tu58 remains an empty file. What must I do to get this working properly?
Thank you.
Al
Booting RT-11 from a TU58 image
Normally RT-11 is booted from some kind of disk: mostly RX floppy, or RK/RL drives.
There's nothing special to make a bootable TU58 image. Since June 2015 SimH 4 supports TU58 as "TDC" device.
Here's the walk through for making a bootable TU58 from a full RL02 system disk, saved in image file "rt11v53.rl02". The resulting TU58 tape image is "rt11v53.tu58".
SimH commands:
sim> set rl0 rl02
sim> attach rl0 rt11v53.rl02
sim> set tdc enable
sim> attach tdc0 rt11v53.tu58
sim> boot rl0
You have no RT-11 running.
RT-11 commands
Copy now the RT-11 core files onto the TU58 images. The size of 256KB allows only for a base system.
.init/noquery dd0:
.copy rt11sj.sys dd0:
.copy dd.sys dd0:
.copy swap.sys dd0:
.copy tt.sys dd0:
.copy dl.sys dd0:
.copy starts.com dd0:
.copy dir.sav dd0:
.copy dup.sav dd0:
.copy pip.sav dd0:
.copy help.sav dd0:
.copy resorc.sav dd0:
.copy/boot:dd dd0:rt11sj.sys dd0:
.dir dd0:
.boot dd0:
"Help" needs much space, but I love it. The RT-11 PDFs on your screen will do as well. Be sure to add all device drivers you need in your '11. Only the Singe Job SJ system is installed, so "??X.SYS" drivers are not needed.
The new tape is verified by booting from it.
Thank you.
Al
SimH commands:
sim> set rl0 rl02
sim> set tdc enable
sim> boot rl0
RT-11 commands
.init/noquery dd0:
.copy dd.sys dd0:
.copy swap.sys dd0:
.copy tt.sys dd0:
.copy dl.sys dd0:
.copy dir.sav dd0:
.copy dup.sav dd0:
.copy pip.sav dd0:
.copy help.sav dd0:
.dir dd0:
.boot dd0:
