Unidentified Commodore cable
flaviosr
Turin, Italy
Dear Group,
can somebody help me to identify the cable of the photos?
I suppose it is a C128 DB9 cable to Commodore monitors but I am not sure.
Thank you
A 25-pin to 9-pin serial cable? I only see one pin in the bottom row and I expected at least two, 7 = RTS and 8 = CTS. I don't know if Commodore Made/rebadged modems. If so, there is a possibility.
Regarding a video connector: vertical sync would be missing.
I think that's a video cable for an Amiga monitor? Question is which one.
That's not a DB-25 -- if I'm counting right, there are only 23 pins (which means it isn't quite a B-sized D subminiature shell).
But, the male DE-9 sure looks like what you might see outputting video for the 80-column mode on a 128.
You've got a real oddball there, that's for sure.
I was wondering that the Amigas have RGB out on a DB23 male... perhaps these cables (I have two) are to be used with Amigas to be connected with old monitors with DB9 connectors...
I see there are a lot of Commodore monitor with DB9 female connectors... what do you think?
Commodore RGB monitors had 3 main types of connectors on the back for inputs (not including LCA and Composite), depending on the manufacturer since they were mostly rebadged. They used a 9-Pin D-SUB both male and female and they used Round DIN cables on mostly the Philips 80 column RGB monitor that they relabeled as a 1084-P. I have a 1084-D and it uses the male 9-pin D-SUB on the back of the monitor. You can tone out the pins with a multimeter and see which monitor it matches up to by using the pinouts in most of the Commodore monitor manuals. But it probably is something like this:
Pin#. Description.
1 Ground. (Amiga RGB Pins 16-20)
2 Ground
3 Red <-> Amiga RGB Pin 3 (Digital TTL Pin 7)
4 Green <-> Amiga RGB Pin 4 (Digital TTL Pin 8)
5 Blue <-> Amiga RGB Pin 5 (Digital TTL Pin 9)
6 Intensity (CGA/TTL Only) <-> RGB N/C or Digital TTL Pin 6
7 Composite Sync (RGB Analog Only) Amiga RGB Pin 10
8 H Sync (CGA/TTL Only) (RGB N/C) Amiga Digital TTL Pin 11
9 V Sync (CGA/TTL Only). (RGB N/C) Amiga Digital TTL Pin 12
These are from my A500 and 1084 manuals. The RGB port on the Amiga is capable of both Digital TTL for 16 colors and Analog RGB for 4096 colors hence different pins on the RGB port depending on which monitor you are using. I did know a couple people that used actual TTL monitors never seeing the amazing colors that the Amiga could produce with Analog RGB.
If you compare the above to the cable then you will know exactly which it is and I would guess that most Commodore cables are ARGB and not TTL. But I seem to remember they did make a cable for TTL too.
