musicforlife
In my EGA computer, Hyundai Super-16T, it's 8088-2 processor and with dip switches it's able to change between 4.77Mhz to 8Mhz. There are a few EGA games that would need at least a slight boost so could I upgrade it into 10Mhz? Does V20 8Mhz make any difference to 8088-2 8Mhz? I don't need 4.77Mhz option because I have already IBM 5150 for those CGA games.
The motherboard contains two crystals: Sunny 24.000 and Sunny SCO-010 1.843200Mhz. There's also 14.31818MHz crystal but that is along with the trimmer which I presume is the same as in IBM PC/XT reserved only for CGA composite output adjustment.
I am only worried that the processor is directly soldered into motherboard without socket so does it withstand desoldering?
