I am working with a Gateway GP7-500 that has two USB ports. I've got it configured for triple boot (DOS/Win, Win95, and Win98). I know I've got the BIOS configured correctly as the USB ports are recognized by Win98SE. I've also gotten the port to be recognized under DOS. For Windows 95, I've installed Win95x OSR2.5 - which comes with USB support. by the way, I think the GL7-500's USB ports are likely USB 1.1, but haven't been able to verify). After installing Win95 OSR2.5 you have to install the USB supplement from the Other>USB folder on the Win95 install CD, reboot, then install a patch from the same directory and reboot - which I did. Oddly, when I plug in a USB disk drive that is recognized under both DOS and Win98SE, Win95 still doesn't recognize the port as being active. The USE device under Devices>Properties shows that a device drive is installed and working properly. I am trying to think of what to do next to get the USB port to recognize the device I know works under the other two OSes.
Thoughts?
Regards,
Mike
Thoughts?
Regards,
Mike
