hexsane
I need the ROM .bin/.hex files for both the CGEN and CODE so I can try to get my card working. I don't have anything that will read or write 2708s so I need both files (you must change both chips at the same time). Its badly out of sync and all I can see is a cursor blinking in 4 locations. CGEN controls sync timing so I'm taking a shot at replacing that to see if it helps.
I have a lose jump wire on the back of my card that goes from pin 3 of a 7425 (I think u21) to point unknown. Anyone else with this card have that jumper? Schematic indicates that it should go to pull up R5 but the trace has been cut and this jumper added.
-Matt
-Matt
