I have been experimenting with a home-made graphics (or rather text) adapter. Based on the MDA concept, with a character ROM and a shift register generating the video signal. But I'm trying to generate a VGA-compatible signal - which partly works...
What resolution does standard VGA 80x25 text mode use? My googling tells me either 640x400 or 720x400. I'm using 60x400 currently, using the timing shown here: http://tinyvga.com/vga-timing/640x400@70Hz
The horizontal and vertical sync frequency is correct (tested with a frequency counter), and the sync signals look correct on the scope. But the picture is not quite right. Using either an IBM 8513 or a slightly newer KFC monitor, I get approx what's shown on the photo. The image is too far left, and a bit too high. If my horizontal sync is a bit off, I guess this could move the picture left. But I don't understand the extra height. I'm sure I have the correct number of lines for the vertical sync and front/back porch. Should 640x400 work on a 8513?
The image is actually sharp - the phone camera just wouldn't focus
