TandyFan
I would like to use the IBM monitor rather than a paper white VGA monitor.
Thanks for the information krebizfan. How would I switch to the monochrome VGA mode? It seems unlikely that a newer computer would have such an option.
As for the actual connection from the computer (VGA) to the monitor (MDA), what kind of pinout would be necessary?
Yes, I know. There's no challenge there. You just plug it in and it works the first time without any adapter, tuning or adjustment.I would like to use the IBM monitor rather than a paper white VGA monitor.
Yes, I've seen quite a few adapters that convert MDA to VGA (for using a newer monitor with an older computer), but not the other direction./QUOTE]
Can you provide some additional info on such adapters? That would be a handy adapter to have...even though it is opposite of what the OP is looking for...
Thanks,
Wesley
I have an IBM 5151 monochrome monitor with a DE-9 connector for MDA. I would like to connect this monitor to a newer computer with a DE-15 connector for VGA.
The VGA output from the computer will display a full screen terminal window with white text and a black background.
Does this thinking make sense?
Hello,
Stone,
I am planning to display a full screen terminal window on the IBM monitor, so there will only be text.
Hi, I found an interesting article that talks about exactly what we need, it's from 1989 and from a magazine called Elektor, it talks about an "easy to build" adapter but I'm not so sure about that. Do you know of anyone who has done a circuit like this? I attach the link of the article in Google Drive. Kind regards
But there’s a couple things to make clear, here: first off, this circuit does no scan conversion. The test case is they’re using it to display output from a PAL BBC micro on a TTL monitor; the difference in line rate between those two standards is about 15% (slower, for PAL) and they run at the same vertical frame rate (50hz), so this is far closer to within specs for the monitor than VGA is, which has a line rate about 80% higher. I doubt many MDA monitors are going to lock onto that.
I think it's not even talking about MDA monitors.
