Kevin Williams
Hello Everyone,
I have a couple of Victor 9000 machines which I picked up without keyboards or monitors. I was lucky enough to snag two keyboards from eBay, but no luck on the monitor. I know it runs a 640x400 mode, but I cannot find any specs on the clock rate, or scan rate. I can't even find the pinout, which I learned the hard way, is non-standard and would seem to be supplying power on at least one pin! Not sure which pins, but I know my MCE2VGA got a new hole in the top of the FPGA after seeing what it would do with the victor! I highly recommend not doing that.
Thanks so much!
-Kevin
Thanks so much!
-Kevin
