renewedgamer
- Joined
- Dec 30, 2022
- Messages
- 9
Hi, I recently acquired another Frankin Ace 1200. This one was not in working condition, but I have been able to get the system to boot, although the video output is not good at all. Very saturated reds/greens. I will post a photo when I get home tonight, but wanted to post this in the case that someone here can help.
I have debugged down to what I believe is the issue based on probing with an oscilloscope and comparing to the other working 1200 that I have.
The issue seems to be at an IC in the video area (near the "front" of the computer) the chip TBP24S10N outputs do not seem to be close to what I am seeing on the working computer.
I looked up the specs on this chip, and it seems to be a PROM. A PROM that probably has been programmed, but is now "not" programmed correctly. Does anyone know if there is a modern replacement or someone that could program an "empty" IC?
Any help would be appreciated!
-J
-J
