wperko
- Joined
- Jul 4, 2007
- Messages
- 498
Hi, I bought a VT-132 emulator from Australia's "TheHighNibble" ... I got the board assembled and at first it was saying I didn't have a PS/2 keyboard attached, but then after pulling power and putting power back ON, now it just gives me this;
<iframe width="560" height="315" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I need help to get the terminal board working, I guess "TheHighNibble" expects anybody that buys his kits to be expert in electronics. I'm not getting any help from him.
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:5404
load:0x40078000,len:13316
load:0x40080400,len:4140
entry 0x40080654
I (412) psram: This chip is ESP32-D0WD
I (422) psram: PSRAM is in 2T mode
I (422) spiram: Found 32MBit SPI RAM device
I (422) spiram: SPI RAM mode: flash 80m sram 80m
I (425) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (432) cpu_start: Pro cpu up.
I (436) cpu_start: Application information:
I (441) cpu_start: Project name: VT132
I (446) cpu_start: App version: V1.5.0
I (450) cpu_start: Compile time: Sep 21 2021 14:53:53
I (456) cpu_start: ELF file SHA256: 8c4e81bffaf67a34...
I (462) cpu_start: ESP-IDF: v4.0.2-4-g877a28e05
I (468) cpu_start: Starting app cpu, entry point is 0x40081648
I (0) cpu_start: App cpu up.
I (975) spiram: SPI SRAM memory test OK
I (976) heap_init: Initializing. RAM available for dynamic allocation:
I (976) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (981) heap_init: At 3FFB6DC8 len 00029238 (164 KiB): DRAM
I (988) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (994) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1000) heap_init: At 4009BE34 len 000041CC (16 KiB): IRAM
I (1007) cpu_start: Pro cpu start user code
I (1012) spiram: Adding pool of 4078K of external SPI memory to heap allocator
I (1033) spi_flash: detected chip: gd
I (1033) spi_flash: flash io: qio
I (1034) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (1272) VT132: VT132 Stand Alone : Running...
I (2189) VT132: USB HOST CONTROLLER FOUND
I (2190) VT132: NO USB KEYBOARD FOUND
I (2190) VT132: Handing UART0 over to USB HOST Controller
I (2194) VT132: Debug logging ends here
rst:0xc (SW_CPU_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
entry 0x40080654
I (413) psram: This chip is ESP32-D0WD
I (420) psram: PSRAM is in 2T mode
I (420) spiram: Found 32MBit SPI RAM device
I (420) spiram: SPI RAM mode: flash 80m sram 80m
I (423) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (430) cpu_start: Pro cpu up.
I (434) cpu_start: Application information:
I (439) cpu_start: Project name: VT132
I (444) cpu_start: App version: V1.5.0
I (448) cpu_start: Compile time: Sep 21 2021 14:53:53
I (455) cpu_start: ELF file SHA256: 8c4e81bffaf67a34...
I (461) cpu_start: ESP-IDF: v4.0.2-4-g877a28e05
I (467) cpu_start: Starting app cpu, entry point is 0x40081648
I (459) cpu_start: App cpu up.
I (973) spiram: SPI SRAM memory test OK
I (974) heap_init: Initializing. RAM available for dynamic allocation:
I (974) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (980) heap_init: At 3FFB6DC8 len 00029238 (164 KiB): DRAM
I (986) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (992) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (999) heap_init: At 4009BE34 len 000041CC (16 KiB): IRAM
I (1005) cpu_start: Pro cpu start user code
I (1010) spiram: Adding pool of 4078K of external SPI memory to heap allocator
I (1031) spi_flash: detected chip: gd
I (1032) spi_flash: flash io: qio
I (1032) cpu_start: Starting scheduler on PRO CPU.
I (1270) VT132: VT132 Stand Alone : Running...
I (2187) VT132: USB HOST CONTROLLER FOUND
I (2188) VT132: NO USB KEYBOARD FOUND
I (2188) VT132: Handing UART0 over to USB HOST Controller
I (2192) VT132: Debug logging ends here
entry 0x40080654
I (411) psram: This chip is ESP32-D0WD
I (418) psram: PSRAM is in 2T mode
I (418) spiram: Found 32MBit SPI RAM device
I (418) spiram: SPI RAM mode: flash 80m sram 80m
I (421) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (428) cpu_start: Pro cpu up.
I (432) cpu_start: Application information:
I (437) cpu_start: Project name: VT132
I (442) cpu_start: App version: V1.5.0
I (446) cpu_start: Compile time: Sep 21 2021 14:53:53
I (452) cpu_start: ELF file SHA256: 8c4e81bffaf67a34...
I (458) cpu_start: ESP-IDF: v4.0.2-4-g877a28e05
I (464) cpu_start: Starting app cpu, entry point is 0x40081648
I (457) cpu_start: App cpu up.
I (971) spiram: SPI SRAM memory test OK
I (972) heap_init: Initializing. RAM available for dynamic allocation:
I (972) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (978) heap_init: At 3FFB6DC8 len 00029238 (164 KiB): DRAM
I (984) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (990) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (997) heap_init: At 4009BE34 len 000041CC (16 KiB): IRAM
I (1003) cpu_start: Pro cpu start user code
I (1008) spiram: Adding pool of 4078K of external SPI memory to heap allocator
I (1029) spi_flash: detected chip: gd
I (1030) spi_flash: flash io: qio
I (1030) cpu_start: Starting scheduler on PRO CPU.
I (1268) VT132: VT132 Stand Alone : Running...
I (2185) VT132: USB HOST CONTROLLER FOUND
I (2186) VT132: NO USB KEYBOARD FOUND
I (2186) VT132: Handing UART0 over to USB HOST Controller
I (2190) VT132: Debug logging ends here
entry 0x40080654
entry 0x40080654
entry 0x40080654
