I connected vt220 to pidp11 via serial console. When I press help key in ked under rt11 the graphic characters are not shown, here is screenshot:
I've seen this topic on pidp forum for similar problem. But solution offered there (adding 'set tto 7b' to boot.ini) did not work for me.
On vt220 the $TERM is set approriately to value 'vt220'. When I use ssh to pidp from linux the $TERM is 'xterm-256color', and ked help still do not show graphics.
Another problem is outside emulation and outside even GNU screen (the terminal multiplexer that hosts simh emulating pdp11). If I try to run midnight commander from vt220 after exiting screen, I also get letters instead of graphics. Also the program responds erratically to keyboard input. But vim works as expected.
If anyone has this setup that works in similar condition please share any necessary tweaks.
Thanks
KED V01.27
Lower Function is GOLD
lqqqqqqqqqqqwqqqqqqqqqqqwqqqqqqqqqqqwqqqqqqqqqqqk
x x x FINDNEXT x DELLINE x DELETE Erase char left
x GOLD x HELP x x x LINEFEED Erase word left
x PF1x PF2x FIND PF3x UNDELLINE x CTRL/U Erase line left
tqqqqqqqqqqqnqqqqqqqqqqqnqqqqqqqqqqqnqqqqqqqqqqqu CTRL/C Cancel
x PAGE x SECTION x APPEND x DELWORD x CTRL/Z Cancel
x x x x x CTRL/R Restore screen
x COMMAND 7x FILL 8x REPLACE 9x UNDELWORD x and keypad
tqqqqqqqqqqqnqqqqqqqqqqqnqqqqqqqqqqqnqqqqqqqqqqqu CTRL/W Restore screen
x ADVANCE x BACKUP x CUT x DELCHAR x and keypad
x x x x x
x BOTTOM 4x TOP 5x PASTE 6x UNDELCHAR x <GOLD>nnn Repeat
tqqqqqqqqqqqnqqqqqqqqqqqnqqqqqqqqqqqnqqqqqqqqqqqu <GOLD>DEL UNDELCHAR
x WORD x EOL x CHAR x x <GOLD>LF UNDELWORD
x x x x x <GOLD>CTRL/U UNDELLINE
x CHNGCASE 1x DELEOL 2x SPECINS 3x ENTER x
tqqqqqqqqqqqvqqqqqqqqqqqnqqqqqqqqqqqu x To return to display,
x BLINE x SELECT x x press ENTER or use any
x x x x function.
x OPENLINE x RESET x SUBS x
mqqqqqqqqqqqqqqqqqqqqqqqvqqqqqqqqqqqvqqqqqqqqqqqj
Thanks
