Chuck(G),
I just wanted to update and say thanks again.
Cindy shipped the AT&T 7300 UNIX PC. It arrived in wonderful condition, and after some careful manipulation, I actually was able to get the machine to boot up, after plugging in the missing keyboard, since I had one from my previous unsuccessful 7300 reconstruct process.
At first, the hard drive would not spin. To get it to boot, I had to take the cover off, plug a standard 5v/12v connector from a modern ATX power supply into the hard drive, and it started right up. After that I plugged the original power connector back into the hard drive, and the system booted just fine from its own power supply.
If you are interested, you can see it here:
http://bit.ly/1mojKGl
Thanks again!
By the way, you say "solve my problem by writing a utility to handle the peculiarities of the Convergent mods to the SysV filesystem. "
This is fascinating...did you happen to keep any of your work/files on this? Without being able to find any available CTIX install tape, I may need to learn how to do exactly this to get our MightyFrames to boot on SysV.
-AJ
