digger
Wanted: image dumps of both 1.43 ROM BIOS EPROMS of an AT&T 6300 or an Olivetti M24
Hello everyone,
Is there anyone out there who has an EPROM reader and happens to have an AT&T 6300 or Olivetti M24 (different brands, same machine) with ROM BIOS 1.43 (no less than 1.43)?
And if you do, could you please be so kind as to dump the contents of both 64kilobit EPROMs that make up the ROM BIOS of the machine and mail them to me or post them on this forum? And when you're done, please don't place them back in your machine backwards, because then I would feel terribly guilty.
I need these images so I can upgrade the BIOS version of our M24 from 1.36 to 1.43. Naturally, I will write the images to new EPROM chips and store the old ones as backups.
I assume that the reason why the ROM BIOS is stored on two EPROM chips, is because the 8086 in the 6300/M24 has a 16bit data bus, and most EPROMs have an 8bit data bus. Therefore, two 64kilobit EPROMS were probably placed in parallel to form a combined 128kilobit ROM BIOS with a 16bit interface. The fact that one of the EPROMS is marked with an 'H' and the other with an 'L' makes this even more probable.
Alternatively, if someone could simply give me a single software dump of the 1.43 ROM BIOS, I guess I could figure out how the BIOS data is interleaved between the chips by assuming that the H-EPROM indeed has the higher byte of the data bus and the L-EPROM has the lower byte. I could then also corroborate that by checking how the current BIOS (1.36) on our M24 is divided between the two chips.
But I would feel more comfortable with separate dumps of the two 1.43 EPROMs, because that would be certain to work.
As soon as I have the images, I'll just go to an electronics store and have the images written to new EPROMS.
Can anybody help me out with this? It would be much appreciated! Also, archiving the 1.43 EPROM images and making them available for any 6300/M24 owner to download would be a wise move in general. As a matter of fact, we should set up a repository somewhere with drivers and ROM images such as this one, which are becoming increasingly hard to find. That would be very valuable for the vintage community!
Thanks.
Hello everyone,
Thanks.
