Anonymous Freak
That's the FPU socket, yes. I always found it odd that the socket wasn't on the main logic board, but basically EVERY IIsi-specific expansion board had that socket.
Well, I didn't find a IICi, but I did find a IIsi, with an Ethernet card installed.
I only had time for a quick look at it today - it boots to 7.01 and has 5MB RAM. It likes to restart when you shut down, though and there's an empty socket on the Nubus card - I don't know whether that's just a space for the optional FPU or something significant.
We're out of town for a few days, then next week is nothing but work, but I'll try to have another look at it the week after. The gubbins have not yet surfaced.
From what I recall the reset button on the back can be twisted to restart on reboot or not.Well, I didn't find a IICi, but I did find a IIsi, with an Ethernet card installed.
Thanks for looking! I don't think the IIsi interests me much.
You have a nice Ethernet card that probably works in a SE/30 making it very desirable.
Many Macintoshes had internal reset and interrupt buttons, which could optionally be made externally accessible by clipping a plastic "programmer's button" assembly.
I didn't see a programmer's switch unit pictured with it, but I plan to print one up on my 3D printer.
Tell us more about your printer. Not that I'm planning on hitting you up for parts that are otherwise unobtanium, but I might.
Congrats on the local IIci find!
It's pretty Jobsian, when you look at it in the right light. Apple saved a couple square inches of pcb space by forcing every add-on manufacturer to waste the same.
If you have a Raspberry Pi or other Linux box that can run the 2.X version of Netatalk, you can use your Linux box as a file server for your IIci, and with your IIci as a bridge, for your 512k.
Thanks! That sounds like a good thing for me to look into. I will probably try building it on my Mac Pro first. If I can't get that working under OSX, then I might run it in a Linux VM, or dedicate a Pi to the task. I have a Linux VM that I use for DECNET, so it wouldn't be the first time I set up a virtual bridge on my Mac Pro.
I've begun checking out the IIci's innards. The RTC backup battery is dead, but it hasn't leaked. The power supply has a few of the Rifa safety rated paper dielectric caps in it, which I will replace with poly film caps of similar ratings. The two 470pF ones are only available as paper dielectric caps at Digi-Key, but I think it should be OK to fudge the value to 1000pF to substitute poly film safety rated caps. Exact replacements are available, but I don't want to have to replace them again in 20-30 years. The insides have the expected decades of dust, but otherwise look good.
I haven't examined the aluminum electrolytic caps on the motherboard yet. The bus routing on the top layer of the motherboard is quite lovely.
Hmm, I wonder if Netatalk would build and run under Solaris 8? That would give me another excuse to turn on the Ultra 60!
