ATADEMO -- ATA Demo Program -- Version 12A2 -- using ATADRVR Version 17A.
! ID word 22 is obsolete, retired or reserved --
! it should be 0000H, however it contains 0004H !
! ID word 50 contains the value 0000H
! when AND'ed with C000H this value is 0000H,
! this value should be 4000H !
! ID word 52 is obsolete, retired or reserved --
! it should be 0000H, however it contains 0200H !
! ID word 69 is obsolete, retired or reserved --
! it should be 0000H, however it contains 4000H !
! ID word 119 contains the value 0000H
! ID word 120 contains the value 0000H
! ID word 93 bits 2-1 are invalid !
ID has set device 0 CHSIncr to
chs_incr=1 num_cyl=8322 num_head=16 num_sect=63.
ID has set device 0 LBAIncr to
lba_incr=1 num_lba=8388576.
ID has set device 0 BLOCKSIZE to 512.
I/O buffer holds 432 blocks (sectors) at this block size.
? DEV 0, LBA28, POLL, 512, TAG Off, PIO WORD, DMA Off, enter command ?
? Cmd ?
