What does that upgrade get you?
TurboROM Overview
1.1. Introduction
The TurboROM is a replacement EPROM for use in all Kaypro
computers that use the CP/M operating system. A complete set of
software utilities and this manual are included with the
TurboROM. The TurboROM provides the following major benefits to
your Kaypro:
1. Disk Speed Improvements:
2X to 4X speed improvements on all disk writes (both hard
and floppy disk drives). Optional disk formats are
supported that provide significant improvements in
disk read, disk write, random file access, and additional
directory entries.
2. Kaypro 10 CP/M System Size and Hard Disk Capacity:
CP/M size increase from the standard 60K to over 63K.
Formatted hard disk capacity increase from 9 megabytes to
over 11 megabytes, depending on the format used to
reformat the drive.
3. New Features:
. Type-ahead keyboard buffer
. Built-in screen-dump
. Cursor configuration (e.g. block, line, flashing,
nonflashing)
. Video screen blanking after approximately 10 minutes of
nonuse (screen saver).
. On-screen time display on '84 machines with clocks
(Kaypro and most of the add-on clocks supported.)
. Auto detection of several floppy disk formats
(including Micro Cornucopia 96TPI).
. Support for nearly all CP/M diskette formats (requires
Plu*Perfect Systems MULTICOPY program).
. Time and date stamping of files (requires Plu*Perfect
Systems K6-B DateStamper, does not require Plu*Perfect
Systems CP/M Enhancements).
4. Hardware Extensions:
. Hard disk upgrades for all Kaypros (up to 112Mb
supported).
. Support for up to four floppy disk drives and 96 TPI
drives
. Support for Advent RAM Disk
. Support for built-in and add on clocks"
