what are the options for vector graphics on a pdp8?
rorypoole
UK, Surrey
I have a large oscilloscope tube in storage that I can use, I cant remember its size but I think its over 3 feet long! I also own a few oscilloscopes, most valve based, what are the hardware options for vector graphics on a pdp8, for the vector graphics controller hardware and vector graphics display's, I could also get an old black and white tv or newer vga monitor and gut it for the crt psu and drivers?
Your ambition is endless my friend. :evilgrin3:
Let me see if I have anything to help you on this. PDP-8's are not "my thing" but as it happens, I recall some items on vector graphics here somewhere, and I'm pretty sure they were for the 8.
Might take me a while. (lots to look through) :hunter:
In the laboratory environment that would be the AX08 (if you mean the 8/I+ era). It included a pair of D/A convertors that were commonly used to drive a long-persistence X-Y 'scope; also a pen plotter. (Also included D/A, RTC, and relay controls.)
Example: http://www.pdp8.net/ax08/ax08.shtml
Documents at that link look as good or better than what I can provide.
Thanks!
home-brew implementation of the VC8/I it looks like it dose not take to meny flip chips
www.chdickman.com/pdp8/spacewar/
www.chdickman.com/pdp8/VC8/
www.chdickman.com/pdp8/VC8/VC8.txt
the site lists VC8/I, VC8E and LAB8 for the pdp8, I will have to look them all up
VC8/I 10bit 1024x1024 with pen interface
LAB8 9bit 512x512 part of AX08
VC8E
it looks like I will be going with the VC8/I
or maybe not
"DEC sold a system introduced 1967 called the DISPLAY-8 or type 338 programmed buffered display which was another PDP-8 which handled all the display processing and could draw 300,000 points, 600 inches of vectors, or 700 characters flicker free at the same time."
http://www.pdp8.net/vr14/vr14info.shtml
could the DISPLAY-8 be built with a 6100 or 6120 pdp8 in a chip? I will have to have a look
so far I have only found user guides for the DISPLAY-8 or type 338 programmed buffered display? I will keep looking for the build info.
I have collected some old CRT VGA monitors, and a 21 and 28 CRT inch tv's cheap to convert to a vector display, I dont know if the tube in the TV's or VGA monitors are better to use, but as they are getting hard to find and are dirt cheap I got both! I also have a few tiny black and white crt tvs to start experimenting on first.
also I am getting a pdp8/e on a chip for the display8 the 6120 is good for 5.1mhz, that should make a good GPU for the straight 8
I have also found David Gesswein's DS32 Emulator Board, its not the same as a real drive, but it is the equivalent of a USB flash drive for the pdp computers!
http://www.pdp8online.com/dfds32/emulator/index.shtml
if you put it in a plastic case to protect it, it would go in a large pocket!
and there is the RL02/RL01 simulator project!
http://www.vintage-computer.com/vcf...r-project-is-finished&highlight=DS32+Emulator
http://www.pdp11gy.com/indexE.html
I dont mind using a hardware emulator boards in my version of the display8
I need to finish my pdp8 straight 8 first
