alpha_sixty
Hello all. I just joined last night, and have already had a great experience with a few people here.
Anyway, I have this quite interesting "computer" that looks to be homemade, and I assume is from the 60's??? (Maybe the 70's...?? I dont know) well, Here is a link to it:
BEWARE: THE PICTURES ARE QUITE LARGE TO SHOW DETAIL.
They could take a while to load...
http://www.cupofhope.info/test/computer/
If you can tell me what this may be, that'd be quite helpful. I found it in a thrift store in Loveland, CO about 7 years ago, and knew then that I had stumbled upon something quite special indeed!
The unit measures (about) 3' in length by 1.5' wide, by 1.5' high.
It all works, (although I blew out the fuse,) and has a schematic on the inside of the lid. I wired it up according to the schematic, and turned it on and most of the lights lit up (I assume some of them are burned out) and the whole thing jumped about 6 inches up and out of the box. Due to it's large size and weight, when it jumped up, it cracked a seam on the box. After about 5 seconds, the fuse on the unit blew, and I havent really looked into replacing it, because I really dont know what it is... The under side of it has large relays that press switches and depending on how it's wired, certain lights on top light up. All of the lamps are definitely old bulbs, as I have seen them on other equipment from the 50's and 60's such as reel to reel players, etc.
If anyone would like more pictures of it, or has more questions about specific pieces, etc. let me know!
Matt
Matt
