keenerb
Do you mean you've seen a similar bus connector (like P1+P2+P3 connector parts) or a similar pin connector (like J3)? That angle-pin connectors are not unusual where there's not much space and straight pins can't be used. I've seen the same, for example, inside keyboards, where the cable is connected.
Some Compaq modem/audio combo cards from the 90's/early 2000's had an extra ISA J3 connector. I forgot about that, I even have a few.
That's an example.
Sadly not the same bus, the spacing/size is completely different.
