andromeda92
Hi,
In a few posts before I talked about two motherboards, KT216WB 16Mhz RAM 1MB and WD286-LPM 12.5Mhz RAM 1MB.
both have 286 processor, I would like to invest in one board not both, I will keep one in the closet waiting.
Which do you think I should keep?
the first is quite complete with two serial ports, a parallel and VGA port integrated into the card, FDD and HDD connector integrated into the motherboard, second with 6 16bit ISA ports including an 8Bite but nothing is integrated, no serial port, port parallel, neither IDE controller nor integrated VGA, I added a video card, an XT-IDE card, or a multi I/O HDD, serial, parallel, and diskette controller, but the diskette controller does not work, even with another 16bit ISA card.
What interests me is above all the stability.
the second motherboard (KT216WB), is hard to find documentation.
If anyone knows these two types of card and could advise me
Thanks for your help.
