watlers_world
To restrict the user to a single driver would seem like a shame.
The OPL,YFM and MPU drivers can all be used at once in a single midi setup.
After you install both my drivers, you should be able to use both the smidi and wmidi drivers in a single MIDI setup.
Just select the driver you want to use for each channel.
WMidirun is a program that gets single midi commands from WMidi.dll
You can choose to have the notes processed by a "Timer" or by a "Loop".
There are several sound output options.
Which were you able to use?
Sndplaysound is the default option. It allows you to play a MIDI using wave files (0..127) on the default MCI wave device.
No mixing is done for this option.
Wavemix uses the 8 mixed channels of wavemix.dll to play wave files for 8 MIDI channels.
PMWM is a custom 16 channel mixer for more powerfull computers.
Xacalite, were you thinking of adding the functionality of smidi to wmidi?
Or were you thinking of creating a MCI Midi driver with MCI Wave output?
