cmc
Hi everyone. In the continuing saga of trying to access FTP/Telnet from my Win 3.1 486 box, I have installed an HP27245-60001 8-bit ISA card. I bought it recently, and the owner claims he tested it for network connectivity. Also, I ran a diagnostic program from HP for the card, and the card passes every test. So I believe the hardware is fine.
I then loaded up WfW and set up the HP27245 drivers included with the Windows installation. I also installed "3.11b" TCP/IP stack for WfW pretty much following this guide:
http://www.yale.edu/pclt/WINWORLD/WFWG311.HTM
The installer made some changes to config.sys and autoexec.bat, the most important of which seems to be to run "net start" at boot.
Everything seemed to check out until the reboot. These rather cryptic error messages showed up as soon as I entered Windows. Without any error codes or log files, I'm pretty much at a loss:
The only thing I could think of from that point was to see if I could get some useful errors from the prompt. Not too much:
I would be grateful for any clues you might have!
