Twospruces
Hi,
I have a Pentium 4 box loaded with Windows 98, to act as a tweener.
The W98 box is on my home network, and I want to use it to transfer files from the outside world to my old machines.
I've come across a strange issue and looking for feedback.
The issue relates to serial ports.
I can successfully use serial to communicate between my old XT and W98 box using PROCOMM. No problem, characters back and forth.
If I then switch to Norton Commander on each end point, the old XT and the W98 box again can communicate no problem.
If I take that exact same set of systems, and try to run Laplink (2 or 3), the W98 box fails. It fails regardless of how I run Laplink - in MSDOS mode or from W98 directly.
I get an error message suggesting the COM ports are not available. Laplink tries COM1 , fails, and then tries COM2 and fails.
Very strange!
I'm glad norton commander works, but why might Laplink fail to work?
Another data point. If I boot using DOS 6.22, Laplink fails in the exact same way.
I've checked the BIOS and the serial ports are enabled using the standard ports.
Since it works for PROCOMM and NC, it can't be that the ports are not set up.
any suggestions?
thanks
Very strange!
any suggestions?
thanks
