If the purchase/checkout system does not support France, an email to the company may be fruitful.A1usedcomputers does not seem either to send to France.
Being 16-bit, you must be writing of the Sound Blaster Pro 2 (as different from the Sound Blaster Pro).A Sound Blaster Pro card will also work fine in an 8-bit slot. It has a 16-bit ISA connector, but only its CD-ROM interface uses the 16-bit part of the bus.
CT1310 - SB 1.0 - 8 bit
CT1320 - SB 1.5 - 8 bit
CT1330 - SB Pro - 8 bit
CT1350 - SB 2.0 - 8 bit
CT1600 - SB Pro 2 - 16 bit
How about that - the CT1330 is 8-bit and the CT1330A is 16-bit.Maybe the original CT1330 is different, but here's the CT1330A and it has a 16-bit connector, although hardly any of the pins on the 16-bit extender are used:
