xenix on a 386
piptay
I have a xenix os on a 386 and it gets through the memory check then halts with one beep and just sits there any ideas anoyone i realy need to get my data off it as i run MAS90 on it and all my details are on it
i checked the hd and all seems to be good under fdisk it shows and in the bios it shows
i knwo there is a piece of software called pc-tar that can restore repair or even convert the data for me but it seems too good to be true at just 15$
any help would be greatly appreciated as i dont think im going to find any hardware to replace even if i could find out what bit has gone wrong
thanks in advance
also not being a unix / xenix user and not being the one who built it can i boot from the floppy as i have them all without ruining the os or data on it i didnt want to try just in case
Terry Yager said:
Yeah, try booting from the floppy and see what you get (just don't format the hdd, if you need any salvageable data that might be on it).
--T
Thanks Terry ill try it today and see if i can get it up i only need it long enough to print the reports then im inputing it into a newly built raid machine for added security :)
thanks again for the prompt reply
hmmm
hmmm
ok i can boot and i get the prompt
Boot
can i try to boot from the hd from here if so do you know the command ive never had to do this before i have documentation but it says to boot from the emergency floppy which i dont have
also im getting header read error: 0
when i try to load /dev/hd0root
this is all at the Boot: prompt
thx
