lucasdaytona
Hi
Adding a 34 pin card edge connector is certainly possible although it does add cost in three ways. I can't tell you the exact amount but it would be more expensive that the XT-IDE since it would have a different planform PCB.
1. increases the rectangular square area of the PCB by a couple of inches (the PCB has to fit in a rectangle and that's how they calculate PCB area, not the actual PCB area itself and you don't get a discount for the material they trim off :-( )
2. gold fingers
3. slot cut into board at keying location
It can be done but it is pricey. Are the card edge connectors used enough to warrant the extra expense? I just converted my floppy cables by clamping on an IDC connector that way you can use either connector. Definitely something to consider though.
Thanks and have a nice day!
Andrew Lynch
Maybe it's best to buy new cables, they are very cheap. I'm concerned (good pointed Andrew!) about the card being fragile in that location.
