VCF Southwest | June, 2025 | University of Texas at Dallas |
VCF Southeast | June, 2025 | Atlanta, GA |
Absolutely! Maybe I'll try making a IDE to SATA adapter first so I can make sure my skills are up to the task before integrating it all on one boardIt might be worthwhile to integrate an IDE-SATA bridge on the board, so that the more common (at this point) 2.5" SATA disks could be used.
How expensive was it to make?
Will this work in a Sharp PC7100? A normal XT-IDE won't work in that machine ("The expansion chassis does not support any DMA mode operations which is required for hard disk operations such as the ones XTIDE would use.")
Someone is/was working on recreating the official expansion card: https://forum.vcfed.org/index.php?threads/sharp-pc7000-7100-expansion-chassis-recreation.1239278/
There is a place to mount a HD on the 1000SX but you have to get a little creative. There is a detachable stress bar atop the left side of chassis. What I did was take apart a standard HD mounting bracket and drill 2 holes in the stress bar and attach the HD mounts to said bar. The HD will then install vertically suspended. There is just enough clearance for most HD's. Easily attaches to your HD controller and saves a precious floppy slot.I figured one would work out well in a Tandy 1000 with no place to mount a HD.
Oh wow! I recently had a similar idea, but with a 3.5" drive and through-hole components on a full-length ISA card. I haven't gotten around to having the boards fabbed yet, but hope to soon.
