I just found an interesting problem. Backstory (Leading Edge Model D): I got a xt-ide deluxe with CF, and the bios address on the card would only go up to D(something or other), but it would not work at that address or anything lower due to a conflict with a SCSI card/ROM. There is an extra ROM socket on the motherboard, so I took the ROM out of the XT-IDE card and stuck it in there, half expecting to blow everything up, but it worked perfectly! But apparently the memory address (F200h) makes one game (Tank Wars) not work, coughing up various "bad file at F200" or "memory string corrupt" or something like that.
I'm not exactly sure what's even happening, but I wonder if there is a way it can be worked around. Can I unload the XT-IDE from F200 (I don't need it on all the time)? Can I force the game to use a different address? Is F200 simply not a safe address to use?
Any insights appreciated!
