modem7
10k Member
Rhetorical question: So, is there something in your computer clashing/conflicting with the card when the card is set to D0000, or is there some kind of fault with your card that shows up when it is set to D0000 ?I reseated the ICs and changed the address. The C800 address change did work and made me able to flash the EEPROM on the first try. Good call! D0000 still has the same issues,
Presumably, you do not have another computer to try the card in.
A 28C64 is 8 KB sized.Another question: Where does the XT-CF-Lite EEPROM address end, so to speak? Ie. from which address can I assign other things (assuming I go with C800h as its starting point)?
C8000 setting: C8000 to C9FFF
D0000 setting: D0000 to D1FFF
Set 'full operating mode' yet ?No difference when it comes to occasional EDIT.COM hanging though.
