Anonymous Coward
If I set XTIDE after the SCSI BIOS without a drive attached, then ASPI7DOS loads just fine.
Very good that at least something got better.Now ASPI can load just fine
Where does it show that? When you try to boot from it or when you have booted from SCSI drive and try to access IDE drive from DOS? Does it show properly on boot menu (correct size etc.)?but the drive connected to the XTIDE is showing "Not ready reading drive D".
Old idecfg displays it wrong since i now use different values.I noticed in the BIOS options that it was set to "32 bit" mode by default, but I also remember you mentioned last time not to play with any of the settings. I did try "16 bit" mode just for the hell of it, but that didn't work either.
With SCSI at D800 and XTIDE at DC00, it doesn't seem to matter which drive I select to boot from, it will boot from the SCSI drive either way, in both cases displaying the "not ready" message for drive D (xtide).
With SCSI at D800 and XTIDE at D000, the system boots to the IDE drive regardless of what is selected in the menu, only the SCSI drive is still accessible as drive D.
so the XT-IDE bios supports tertiary ide controllers aswell?
[snip]
Should i use v2 or v3 of the GPL?
I can send sources to anyone that wants it as long as any modifications will be send back to me. XTIDE Universal BIOS is written in 100% Assembly using Nasm syntax. It compiles with Nasm and Yasm (i recommend Nasm since Yasm has a buggy CPU directive).
