per
I was testing the CGA_Comp program today, and all the tests was running fine, however, when I did the Hardware detection, it reported a runtime error durning loading data of the floppy, and then the floppy drive just stopped working! A cold boot won't help, and I guess my drive either has dirty write/read heads or some serious unalginement.
The strange thing is that it worked all fine before this, no problems at all, so I don't think the algiment is the problem.
On POST, the red led flashes as usual while the heads move, the computer makes the usual BEEP, but when it tries to load the floppy, it just spinns, and doesn't move the heads at all.
It's a FH 360K drive or more commonly reffered to as a IBM type 1 Disk Drive.
I would like some advice in what to do.
