Zenith ZWL-183-93 revival
compaqportableplus
USA
I finally got me a Zenith ZWL-183 laptop, the -93 variant to be exact, so it has a 20MB hard drive versus the 10MB the -92 has.
Here was how it look when I first got it out of the box:
Pretty dirty. You can also see my other new toy sitting under it that I will be making a thread about very soon.
When I fired it up, I was greeted with this:
Seems to be a VERY common issue with these. I figured the JVC 26-pic hard drive probably had stiction, which it did.
Here is the drive liberated from the Zenith:
Heavy as hell! I really can't believe how much this little drive weighs.
So, I got it unstuck, but it wouldn't spin-up when you first powered the computer on, you had to do a ctrl+alt+delete and then it would spin up, weird! It would just spin right back down though, and I would get the drive error again. I spent several hours on it and couldn't figure it out, so right before I went to sleep I was reading a thread on here from someone that had one, saying that the hard drive worked fin until the battery died.
Well, I wasn't going to be able to sleep knowing that, so I got up, connected an ATX PSU to the battery terminals, plugged in the Zenith power supply, and the damn thing booted right up! It was at a prompt that said "Enter Password Attempt 1" or something like that, so I felt pretty good about that and went on to bed.
Today, I decided to make a small and entirely reversible modification to the little power board inside of the laptop. I discovered that removing the little choke coil from that board takes the DC barrel jack completely out of circuit, so I pulled that out, and then just ran wires from the jack straight to the positive and negative points for the battery, allowing me to plug my 12V 2.2A power supply into the side of the machine like normal! No more "low power" light and the hard drive now works as it should! I also wired it for the more traditional center-positive, rather than center-negative like this laptop originally was.
Someday, I will build a proper battery for and probably reverse this, but for now it's working great.
So, if you have one of these and think the HDD is toast, it may not be! It could simply be that the unit isn't getting enough power.
I have found that when it sits for a while the drive does get stuck again sometimes, but I found a firm, flat-handed "smack" over the drive seems to always get it going again! :D Thankfully, the stiction this drive has seems to be pretty mild, for now at least.
I also was having issues with the disk getting stuck in the floppy drive, so I pulled it out and found the offending part of the mechanism, oiled it, and it's working great now! Ejects disks very smoothly. First time I have had that issue on a PC. It's usually Macs that have that problem. Bit of a pain getting the two springs for the pop-up assembly on and off, but it's doable. They're really strong springs.
Here it is all back together and working:
Sure is a cool laptop. VERY big too! Love the way this JVC hard drive sounds also. I was able to get around the "password" thing by just removing a command from the autoexec.bat. :) Still has the original Zenith MS-DOS 3.21 on it! I have already backed that up, along with some other stuff. I will probably format the drive and start fresh with it.
I also found something really funny on this hard drive I will share a little later.
More to come!
Okay, so here's something hilarious I found on the hard drive. I saw that it had a C:\WINDOWS directory and got excited, as I have never found Windows already installed on a computer this old. So I went to the directory and typed "WIN" to be greeted with this:
:rofl: I definitely got a kick out of that. It's just a simple batch file. I did save it too so if anyone wants it let me know. I placed it in a directory called "WINDIE." :razz:
Of course, I did put actual Windows on it too:
This is version 1.01. I will be putting 2.03 on it also.
Here's is the CheckIt system report as well as a hard drive benchmark:
About the same performance as a typical MFM hard drive.
I may install an NEC V20 in this laptop as well, as I did on my ZFL-181.
As someone who lives less than a mile from the old Zenith HQ/ factory (and a modest Zenith collector), this thread warms my heart. Very nice to see and I enjoyed the humorous "trap".
Thanks! That’s really cool that you live close to the old Zenith headquarters.
Glad you enjoyed funny batch file. :)
Hey,
I have one of these same laptops, and I get the "low power" and hard drive failing to start up issue too ever since the battery exploded.
Have you built another battery for it yet? Is there any chance you could help me out and build another so I can buy it, or do you have some other easier solution?
🤣 I definitely got a kick out of that. It's just a simple batch file. I did save it too so if anyone wants it let me know. I placed it in a directory called "WINDIE." :razz:
View attachment 1039762View attachment 1039763
View attachment 1039764View attachment 1039765
If you can, go ahead and re-cap the hard drive first chance you get. these have surface mount capacitors on them and they were all leaking or close to leaking on the one in mine. Attached are the pics of all the capacitors that need replaced. After doing this, you're also going to notice that the seek times increase, and it'll be a lot easier for the drive to start spinning as well, a problem I had for a while with the old capacitors. The 16v 22uF was the only real one that showed any leakage, but I swapped out all the rest of the ones pictured as a precaution as if one is going, better to replace all the others.
I'm going to be so glad when someone decides to really dig into the protocol these JVC drives use and make a CF adapter. it's going to make life so much easier.
I used to work for ZDS from 1990 to 96, when they packed up and shut the doors. I started out at repair depot in Three Oaks, then they moved us back up to Hilltop. Our department was on the other side of the office mezzanine by the cafeteria, then they moved us back to the old SMT area.
Most of what I did in the early days was repair contract work at the field service unit level, then was laid off. I got recalled a couple months later, then I was transferred to component repair. I spent rest of my career there repairing 486 desktops boards. Near the end we were also re-working re-branded Packard Bell boards. Their firmware was sucky, and I spent most of that time replacing Roms.
The thing I hated about the ZWL-183 series was when the charging circuits would burn up, and melt the side of the case. We'd have to gut the machine and replace the entire bottom "tub" of the plastic case. Besides the 20mb JVC drives, I recall them having 10mb ALPS hard drives.
Thank you for posting this! It gives me a great starting point for the one I recently acquired as all of my indicators/issues are the same as yours!
I also have a zenith ZWL-183-92 in much better condition visually then this one - the HDD on that one missing though but it does boot to a prompt.
I've just got a 183-92 as well. It seems to have the same symptoms.the drive
I was amazed that the battery charged up (using a configurable charger set to 15v - I belive the proper Zenith one is 16.5v) but it only runs for about 30 minutes.
It does try to boot from the HDD but fails (no sound of anything happening) and never tries the floppy drive. I did find that I could boot from the floppy by bringing up the monitor and typing b0, but that's a bit clunky. Can it be configured to ignore the HDD?
What's the best advice for reviving the JVC HDD. Is recapping helpful, and what about the choke removal idea? I took out and gave it a shake and also put a tiny drop of clock oil on the spindle which seems to turn OK. Is it possible to free up the heads manually, the exposed mechanism seems locked up tight.
Just for info I downloaded an image of the Zenith dos disk from Winworld in case anyone needs one.
I finally managed to get the HD to spin up. The heads were completely solid, no movement at all. I tried to peer under the disc which is on top of the motor coils and I could see some crud. I judicious tap and with a bit of grinding it started to move. The underside had rusted, so a thin bit of emery paper and I managed to free it up. The main spindle seems to have one position where it is reluctant to move, probably due to the magnets but if positioned in the looser bit it spins up fine (and sounds great!). I'm guessing that it needs more startup current if its in the stiff position. Once running, more rust dust came out from under the head disc and it seems to work fine if you can get it to start.
nice work, thanks for sharing your progress so far, I am reading these posts in reference to the 2 Zeniths I have - they've been cleaned-up and power-up/boot but yeah my HDDs are not working either, everything else seems to be ok, batts need some resto-modding as well.
Sadly the HDD won't stay working. Whenever I shut it down there is a good chance it won't boot up again (usually immediately after ive put everything back together). The annoying part is that when it fails to spin up it doesn't try to boot from the floppy drive so i have to boot from the monitor.
In trying to theorise what is happening and causing the stiff patch I came up with these:
  1. One of the motor segments has failed
  2. The motor bearing has crud in it
  3. The platter lubricant has gone sticky and is adhering to something at a particular point in its circumference
  4. The heads are sticking to the platter
Any of these would require opening the drive up. 1 would be hard to fix and I don't think it's 4 because the heads seem to move OK even when it's seized up.
If anyone has opened one of these up I'd be grateful for any pictures and whether the repair was successful, or indeed any other thoughts.
