SiriusHardware
Falter: If you mean something like a hi-fi cassette deck 'separate' then I'm afraid you'll have problems there as well.
The 'Tape out' or 'Line out' jacks on the rear of the deck will usually be at a fixed level, almost certainly not the level you need. (Occasionally, the output level is variable).
If the deck has a phones-out jack as they often did, it's very unlikely to be powerful enough for your needs. Only the phones - out socket on something designed to directly drive a speaker (internal or external) is likely to have enough power.
Thin black lines half-heartedly waving about in response to the input is a pretty typical symptom of the input signal not being at a high enough level.
You're right that if you are using a stereo source it's generally best to use only one channel output to drive the ZX81 because any phase differences (or any differences at all) between the right and left channels will mangle the signal that the ZX81 is expecting to see. If you only use one channel output or the other, then any differences between the two outputs will not cause problems.
You were going to post one of your .WAV files here, why not do that and then at least we can see if your file is OK and rule that out?
Cthulhu: The ZX81 was designed to work with only one thing, a typical contemporary mono cassette tape recorder / player. All the other things we're discussing here (Laptops, MP3 players) obviously didn't exist. Regarding the transformer, can you suggest a suitable part number from a USA / Canadian supplier? (Falter looks to be in Canada, I am in the UK but we don't know where you are).
