Normally the SOICs that I end up using have a smaller pitch than that. Just general experience. It’s, of course, all about the pitch size.
Yeah, I was looking at the biggest-size ones for the 74x series parts. I have a *little* experience with soldering those and they don't intimidate me *too* much, but my confidence level rapidly plummets after that.
I really wish the company that made those PSRAM chips we decided to go with for this had come through with making the TSSOP version teased in the datasheet of their 8 Megabyte chip, the reduction in package count would certainly be nice.
FWIW, I did browse the company's website directly to see what they had on offer, and they do have a four megabyte (2Mx16) SRAM part. It sells for about $25, which would make the RAM cost about twice as much. (The 1MB PSRAM part is around $3.) This part would reduce the number of packages by 75% for a given amount of RAM, but in addition to the cost it's a .5mm pitch part instead of .8mm, and that may be an important threshold because .5 is smaller than the minimum Via diameter on the cheap 2-layer PCB boards, which would not only make soldering a bear it'd also probably make routing a lot harder.
I guess maybe I'm getting a little worried if there are going to be drive/fanout issues with this many parts. Maybe it's nothing to worry about, there's those old S-100 cards with a gazillion SRAMs on them and they seemed to work. It was just sort of making me wonder if there should be a separate set of buffers for, I dunno, each row of 8 or so chips. I guess that's what doing a prototype is supposed to find out.
