neosunrise
I recently made some disks using ImageDisk for my Osborne 1. It has the floppy drive upgrade with two double density drives. The disks booted and was read fine on the Osborne 1 (I had to change the transfer rate from 250kpbs to 300kbps in ImageDisk though). Now I wanted to copy some files to the disks using 22DISK from my 486 DOS machine (which has a 5.25" floppy drive that supports both DD and HD disks) but no matter which disk format I set it to (SSSD, or SSDD for Osborne 1), it won't be able to recognize the disks.
Am I out of luck?
Am I out of luck?
