QuantumII
Hi all
Just recently my luggable Philips Logic Analyzer PC (xt clone with extras)'s 256K ISA card stopped working.
It began with a memory error on boot, and on the next reboot it only counted up to 256k (wich is on-board)
The 8-bit ISA card does not seem to be alive at all, and I cannot find any documentation it..
However, if I move around on the DIP switches on the card the PC does not boot at all, so it does _something_
First I thought that is was just a bad connection between the motherboard and the ISA card, but moving it around in other slots makes no results. the machine still counts up to only 256k both with the card in the slot or without.
I think I may need to replace the card.
There are pictures of the card here: it has 4 large IBM branded chips, each at 64k (I believe) making up a total of 256K.
Front
Have any of you seen this card before, or have any info on it? Is there any other cards of the same type you can recommend ?
Front
