Al Hartman
You need to try this drive in another computer, and if possible, try another drive in this one.
Maybe you have the wrong cable for this motherboard?
I think your drive is probably fine--the 16/12 grounding test pretty much confirms that. I suspect your cable or your motherboard. Do any other floppy drives work correctly with this cable and/or motherboard?
Floppy drives are very simple devices--not anywhere close to the complexity of a hard disk. If you can spin the motor and illuminate the LED by grounding a couple of pins, it's no different from what your motherboard should be doing.
That LED thing is quite normal for Windows 98. Linux sometimes behaves that way also. <shrug>
If you're going to format 360K disks, they have to be double-density, (DSDD), not high-density. I've seen fully degaussed DSHD hold double-density data, but that's a bit extreme--and I doubt that you own a big enough bulk tape eraser.
Also, if you're not averse to running DOS (i.e. shut down Windows to a command prompt), you might try Dave Dunfield's ImageDisk. It's got all sorts of useful testing in it.
I am trying to format high density 1.2M disks. I got ImageDisk running in DOS, then ran TESTFDC. Again, no signs of the drive actually reading the disks, but here are the results:
SD at 250 kbps - not tested
SD at 300 kbps - failed
SD at 500 kbps - failed
DD at 250 - 500 - not tested
Have you tried a different cable?
Have you tried TESTSD with a 3.5" drive to see if single-density even works with your system? If it doesn't, those test results are kind of meaningless, aren't they?
