mvno_subscriber
Hi,
one of the floppy drives of a system I recently got hold of made this "tac tac tac" noise while the disk was in and spinning. I identified the culprit being a ring of some sort between the big white thing that pushes the disk down so it starts spinning when you close the drive (sorry, I have no idea what that part is called), and a spring.
I had a look on the other floppy drive, and it didn't have that ring. I have no idea if it was an original repair to fix a spring that wasn't stiff enough or something, but it's making a lot of noise because the spring is "popping" off the ring (see, the ring isn't whole, it's only partial).
Now in order to fix this I would need to disassemble it, but I have no idea how to take it apart. Can anybody help me here? I've attached an image hopefully showing my issue..
Since I'm not a native English speaker, especially names of mechanical parts are not part of my vocabulary. Sorry
The drive is otherwise working just fine, but the noise makes it hurt every time I use it.
