6800 to 6809 adapter needed
Ruud
Heerlen, NL
Hello,
I own a Eurocom-1 computer equipped with a 6802 CPU. A Dutch book mentions a small adapter with a 6809 on it that you plug in the place of the 6802.
My questions:
- Does anybody know where I could get such an adapter?
- Does anybody know a schematic so I could build one myself?
Many thanks in advance!
Hello,
My questions:
I have one, I'm not selling it but let me see if I can reverse engineer it and post schematics
I have one of those boards for a MEK6802D5 board I have. I don't have it running but the boards contains a 6809, a 74163, 74LS08, a 74175, a 74LS00, a 74LS04, 74LS74. I'll need to reverse engineer the board and post the schematic. It's a single sided board with about 10 jumper wires. The board is from about 1985.
Just out of curiosity, I had a look at the MC6802 datasheet. It has some built-in RAM (128 bytes if I'm not mistaken), I thought it would be easy to come out with an adapter schematic if it was really impossible to find an original one. It seems to me anyway that a general purpose replacement board should contain at least that small amount of RAM. The chips you mentioned are only general purpose logic, so it might work in a place where the internal 6802 RAM is not used. However, I might be mistaken of course.
Best regards
Frank IZ8DWF
Frank you are correct, if the board for the 6802 has no ram then the 6809 will have some trouble running (it's possible to write code that doesn't use ram but I won't do it ;-) ).
I've got pictures of the board and I'll upload them to my site and provide a link here. The pictures are large and I doubt I have permissions to post links yet (new user, less than 10 posts).
I just had a look at the Euro 1 and I now see how Frank comments relate. He is correct the 6809 has no RAM internally. So you'll need to add RAM and the decoding for it. Also the 6802 ROM code won't run on the 6809. So it's not a drop in replacement.
This would be something I am interested in as well. Is anyone going to look at knocking out a designing based on above screenshots and putting it on somewhere like oshpark? Or is this something I will have to look at doing when I have a free slot in my todo list (somewhere in the next 10 years).
Oh, sorry forgot to add this. I seem to recall this design coming from an EE magazine. I recall seeing the article. I am finding it really odd the I can find that information in a search of the internet.
But the Eurocom has 1 KB RAM of its own starting from $0000. The lower RAM isn't used because the 6802 will use its internal RAM. The PCB on the picture in the book is very small. IMHO it is just a 6809 plus maybe two IC under it, certainly no extra RAM.
I used to have a Motorola D2 kit. It used a 6800 processor. I eventually modified it to use a 6809 processor and rewrote the monitor software to work with the 6809 and handle the extra registers it has. The board I designed and built to allow a 6809 to plug-in to the 6800 socket used only 2 diodes, 2 resistors, and a transistor. I no longer have my D2 kit but I remembered the diodes were an OR gate and the transistor was an inverter. I went over the datasheets for the 6800 and 6809 and have worked out what I had done before. I've drawn up a(n untested) schematic for it. I also looked at how to plug a 6809 in to a 6802 socket and worked up schematic for it as well. The only catch is that the simple 6802 to 6809 mod doesn't include memory. If any one is still interested in using a 6809 in place of either a 6800 or 6802 I could made the schematics available.
Ruud,
I'm so sorry I didn't see this post earlier.
The Heathkit ET-3400 Microprocessor trainer was a 6800-based single board computer. There was a follow-on called the ET-3400A that used a 6802 or 6808 (It didn't use the on-chip RAM). There were several instructional courses that went with these machines. One of the optional courses was EE-3404, "6809 Microprocessors". The purpose of the course was to have the student become familiar with the 6809. The course came with an adapter board and which would plug directly into the CPU socket on the ET-3400 or ET-3400A. In the case of the ET-3400 (the earlier 6800-based version), you also had to replace the 6875 clock chip with a header that re-routed some signals.
This is all documented in the EE-3404 manual.
The information, courses, schematics are all available in the files section of the yahoo group ET-3400:
https://groups.yahoo.com/neo/groups/ET-3400/info
Gilbert
Hallo Gilbert,
I joined the group and will see what is available. Thank you very much!
I checked everything AFAIK but the EE3404 part contains the only documents regarding the 6809. One of the PDFs mentions a part list but no schematics. It also shows a picture of the Heathkit with module. The module contains two TTL ICs, a crystal and an EPROM, for example, parts not mentioned at all in the parts list. More than a bit confusing.
My first idea was anyway to look for a direct replacement: just a 6809 plus maybe an IC (Kevin's design). But I'll give it another thought now.
