harry
I have been spending some time trying to resurect a CBM 8032, the machine, although cosmetically very good, appeared dead. I have checked many things, one thing I found, was no -5v on the dram, after replacing the bridge rectifier, (cr2,) & caps, and diode, the -5v was now good, except there was a short from somewhere on this -5v supply to the ram chips,which being all soldered in,finding this was going to be impossible for me, so I replaced all 16 ram ic's with sockets, and fitted what was good 4116 ram I had,into these sockets, the fault was now gone, but the machine still showed no sign of life.
I have a smilar 8032, still working,thanks to Anders, who supplied me the m/b many moons ago.so I used this to check out the roms one at a time, and found three of them faulty, and of course these would only produce a blank screen. I decided to download the rom images and make a complete set of new roms using 2532 eproms. When fitted there was still no life? so I decided to check out some signals with the logic probe, which showed the 6502 address lines were all high? I replaced the 6502, and now had some life on screen, but mostly double brackets every where. The 2116 video ram was luckily in sockets, and replacing two of these cleared up the screen. and the "commodore " text was sort of there. I had no chirp when switching on either? swapping the 6522 gave me the chirping back, (or bleeping if you like, )when switched on, so things were looking good, ....BUT looking at the message on screen you can see the characters are not correct, I swapped the character rom over from the other machine, but nothing improved, I am strugling to understand the way the characters are enabled, and sent to screen, and would welcome some help to sort this problem, If I use the keyboard,some letters, or no.'s appear as typed, others will produce an incorrect letter first, but strangely, if the same key is typed again the correct letter appears, and changes the previous incorrect letter to the correct one typed? I have tried to explain what is happening, but I could take some more pics if needed. many thanks harry
