(NOTE: All pictures referred to in the course of the text posting are seen at the end of the posting.)
Picture number 1 shows the current configuration of my AT&T 6300. The computer houses the basic 6300 architecture along with boards for a Perstor HD controller, WD Paradise VGA video card with 256 KB video RAM, Boca 2MB RAM Card EMS 4, MS Bus mouse card, and I/O card for COMM3 with LPT2.
The following shows results from Checkit's Memory Map as shown in picture 2 highlighting the video RAM, there is a problem with the Paradise VGA video RAM as seems to use only half of the 256 KB video RAM. Checkit's Testing of the Video Memory generates a parity error as shown in picture 3. In addition, Checkit's testing for color produces just B&W (i.e., color is lost) with different grayscale levels as shown in picture 4. In addition, picture 2 shows the addresses C000-C600, 24 kB, as the Video ROM address. Picture 5 shows the unknown ROM, which appears to be nothing identifiable except for the 8 kB ROM covering addresses C600-C800; the Prester HD Controller addresses are C800-CA00 as shown in picture 7. The E000 is the Boca RAM card as shown in picture 6, however, I have Quart Deck QRAM.sys set up for /R:1 /FL=0, which is applying 64 kB to memory from the RAM card, however, I am reading their manual to attain a better understanding of EMS application. The last R in the memory map of picture 2 for the machines 1.43 ROM as shown in picture 8.
Lastly, a summary of the InfoPlus is included below:
InfoPlus Results
Page 1
Infoplus 1.58 Page 1 - Machine & ROM Identification
Generated: Fri, Aug 28, 2020 at 2:59:45 pm
Machine type: (unknown machine - model byte 00)
BIOS source: COPYRIGHT (C) OLIVETTI 1984
BIOS date: 04/03/86A
BIOS extensions:
Segment Size Copyright notice
C000 24K 003056-007COPYRIGHT PARADISE SYSTEMS INC. 1987,1988, ALL RIGHTS
RESERVEDVGA=U
C800 8K COPYRIGHT(c) PERSTOR SYSTEMS INCORPORATED, 1987-88
Infoplus 1.58à Page 2 - CPU Identification
Generated: Fri, Aug 28, 2020 at 3:01:28 pm
CPU: 8086
Interrupts acknowledged immediately after segment register change: no
Coprocessor: 8087
Infinity: projective
Rounding: to nearest or even
Precision: 64 bits
BIOS coprocessor flag set: yes
BIOS Weitek coprocessor flag set: Not Applicable
Infoplus 1.58à Page 3 - RAM Identification
Generated: Fri, Aug 28, 2020 at 3:01:56 pm
Total conventional memory (bytes): 655360 (640K)
Free conventional memory (bytes): 414752 (405K)
Extended memory (from BIOS call): N/A
XMS driver present: no
DPMI driver present: no
Expanded memory:
Interrupt vector: 0B87:1893
Driver: EMMXXXX0 status: available version: 4.0
Page frame segment: E000
Total EMS memory: 2048K available: 2048K
VCPI capable: no
Handle Size Name
Infoplus 1.58à Page 4 - Memory Block Listing
Generated: Fri, Aug 28, 2020 at 3:02:23 pm
MCB PSP Parent Size Env Owner Interrupts
0B85 0008 0014 21136 DOS
10AF 10B0 10B0 4704 COMMAND.COM 2E
11D6 10B0 10B0 64 COMMAND.COM
11DB 10B0 10B0 256 O COMMAND.COM
11EC 3A00 3A00 80 COMMAND.COM
11F2 11F3 10B0 16896 COMMAND.COM 08 0B 2F 33
1613 161B 10B0 96 O PARADISE.EXE
161A 161B 10B0 1056 PARADISE.EXE 10
165D 1665 10B0 96 O XTG.EXE
1664 1665 10B0 119136 XTG.EXE 30
337B 1665 10B0 7168 XTG.EXE
353C 1665 10B0 8176 XTG.EXE
373C 1665 10B0 8176 XTG.EXE
393C 1665 10B0 3104 XTG.EXE
39FF 3A00 3A00 2640 COMMAND.COM 22 23 24
3AA5 3A00 3A00 256 O COMMAND.COM
3AB6 3ABE 3A00 96 O INFOPLUS.EXE
3ABD 3ABE 3A00 414752 INFOPLUS.EXE
Infoplus 1.58à Page 5 - Video Identification
Generated: Fri, Aug 28, 2020 at 3:02:57 pm
Active video subsystem: VGA + analog color
Inactive video subsystem: (none)
Initial video mode: 80 x 25 color
Current video mode: 3 (80 x 25 color text)
Current display page: 0
Graphics modes: 3
Video buffer (offset): 0000
Video buffer size (bytes): 4096
Active display port: $3D4 (color)
CRT mode register: $09
Current palette: $30
Colors: o++++++++++++++++o
Current colors: white on blue
Text rows: 25
Text columns: 80
Scan lines/character: 16
Cursor scan lines: 6-7
Infoplus 1.58à Page 6 - Video Information
Generated: Fri, Aug 28, 2020 at 3:03:50 pm
Display adapter: VESA version 1.0
OEM ID: Western Digital Inc Manufacturer: Western Digital Inc
Video modes supported:
Number: 0100 Mode: Color graphics BIOS output support: yes
Screen size: 640x400 Character size: 8x8 Colors: 256
Memory model: Packed-pixel Memory planes: 1 Memory banks: 1
Number: 0102 Mode: Color graphics BIOS output support: yes
Screen size: 800x600 Character size: 8x8 Colors: 16
Memory model: 4-plane Memory planes: 4 Memory banks: 1
Display adapter: VGA
Chipset: Western Digital/Paradise PVGA1A
Video: 8-bit ROM: 8-bit Frequencies are: fixed-sync
Font Address
INT 1FH C000:0C00
INT 43H C000:0800
ROM 8x14 C000:1000
ROM 8x8 (lo) C000:0800
ROM 8x8 (hi) C000:0C00
ROM 9x14 C000:1E00
ROM 8x16 C000:1F2D
ROM 9x16 C000:2F2D
Display type: color
Memory: 256K
Palette registers: 00 01 02 03 04 05 14 07 38 39 3A 3B 3C 3D 3E 3F
Border color: 00 Color page: $00 Paging mode: 4 pages of 64 registers
Infoplus 1.58à Page 7 - Keyboard & Mouse Information
Generated: Fri, Aug 28, 2020 at 3:05:00 pm
Keyboard:
BIOS support for enhanced keyboard: no
Insert: off Caps Lock: off Num Lock: off Scroll Lock: off
Buffer start: 0040:001E end: 0040:003E size (keystrokes): 15
Internal modem [IBM Convertible]/serial printer [PCjr]: no
Game port: no, and NOT set in BIOS equipment word
Mouse: yes Buttons: 2
Microsoft version standard: 8.20
Type: InPort Interrupt: IRQ3
driver type: TSR cursor type: software no. of MDD's: 37
interrupt rate: 30Hz acceleration profile: 2 BallPoint: no
.INI file path: C:\DOS\MOUSE.INI
pointer - style: normal size: small size change: no
EGA register support: yes version: 1.52
Save state buffer size (bytes): 399
Mickeys/pixel (horizontal): 50 (vertical): 50
Double speed threshold: 50
Language: English
Infoplus 1.58à Page 8 - Parallel/Serial/Sound Ports
Generated: Fri, Aug 28, 2020 at 3:05:22 pm (Note: Reordered before second i/o
card installed.)
Printers: 1 Serial ports: 1
Device: LPT1 Device: COM1
Base Port: $0378 Base port: $03F8
Timeout: 20 UART: 8250
Busy: yes Timeout: 1
ACK: no Baud rate: 2400
Paper out: no Data bits: 8
Selected: no Parity: none
I/O error: no Stop bits: 1
Timed out: no Break: no
RLSD: no
Sound cards: RI: no
Ad Lib (or compatible): no DSR: no
Sound Blaster: no CTS: no
Roland MPU-401: no dRLSD: no
Gravis Ultrasound: no -dRI: no
dDSR: no
dCTS: no
Infoplus 1.58à Page 9 - DOS Information
Generated: Fri, Aug 28, 2020 at 3:05:46 pm
DOS version: 6.22 revision: A File Control Blocks:
in HMA: no in ROM: no amount: 4
OEM serial number: FF Stacks:
System date: Friday, 8-28-2020 amount: 9 size each (bytes): 128
System time: 3:05:30.15 pm
Command load paragraph: 3ABE ------ International Information -----
Ctrl-C check: off Global code page:
Disk verify: off Active: 437 Default: 437
Switch prefix character: / Country code: 1
\DEV\ prefix for devices: optional Country: United States
Reset boot: preserve memory Thousands separator character: ,
Boot disk was: C: Decimal separator character: .
DOS critical flag: 010F:0320 Data-list separator character: ,
DOS busy flag: 010F:0321 Date format: USA (mm-dd-yy)
Printer echo: off Separator character: -
PrtSc status: ready Time format: 12-hour
Memory allocation: first fit Separator character: :
DOS buffers: 10 Read-ahead: 0 Currency format: $x,xxx.yy
File handle table: 3ABE:0018 Case map call address: 010F:0CF5
length: 40 used: 5
Open file handles:
Table at: 010F:00CC table size (handles): 5
AUX open mode: read/write sharing mode: compatible inherit: no
attributes: (none)
remote: no date: 1-1-1980 time: 12:00:18 am
size (bytes): 0 (0.0K) DOS device
CON open mode: read/write sharing mode: compatible inherit: no
attributes: (none)
PRN open mode: write sharing mode: compatible inherit: no
attributes: (none)
Table at: 0E3C:0000 table size (handles): 35
(none used)
Infoplus 1.58à Page 10 - Multiplex Programs
Generated: Fri, Aug 28, 2020 at 3:06:27 pm
Multiplex interrupt ($2F)
DOS: yes
DRIVER.SYS: yes
DISPLAY.SYS: no; OK to load
ANSI.SYS: no; OK to load
EGA.SYS: no; OK to load
PRINT: no; OK to load
ASSIGN: no; OK to load
SHARE: no; OK to load
NLSFUNC: no; OK to load
GRAFTABL (4.0-): no; OK to load
GRAFTABL (5.0+): no; OK to load
NETBIOS append: no; OK to load
NETBIOS network: no; OK to load
SHELLB: no; OK to load
XMA2EMS: no; OK to load
APPEND: no; OK to load
GRAPHICS.COM: no; OK to load
Crit.err.handlr: no; OK to load
CDROM: no; OK to load
Network: no; OK to load
DOSKEY: no; OK to load
DOS Extender: no; OK to load
Infoplus 1.58à Page 11 - Environment Variables
Generated: Fri, Aug 28, 2020 at 3:07:51 pm
Program name: C:\TESTING\INFOPLUS\INFOPLUS.EXE
Environment:
Segment: 3AA6 Size: 256 Used: 61 Free: 195
Variables:
COMSPEC=C:\COMMAND.COM
PROMPT=$p$g
PATH=C:\;C:\DOS;C:\WP51\
Infoplus 1.58à Page 12 - Device Drivers
Generated: Fri, Aug 28, 2020 at 3:08:13 pm
Device Units Header Attributes Strategy Interrupt
NUL 010F:0048 1000_0000_0000_0100 010F:0DC6 010F:0DCC
EMMXXXX0 0B87:0000 1000_0000_0000_0000 0B87:0012 0B87:001D
CON 0070:0023 1000_0000_0001_0011 0070:06F5 0070:0700
AUX 0070:0035 1000_0000_0000_0000 0070:06F5 0070:0721
PRN 0070:0047 1010_0000_1100_0000 0070:06F5 0070:0705
CLOCK$ 0070:0059 1000_0000_0000_1000 0070:06F5 0070:0739
4 0070:006B 0000_1000_1100_0010 0070:06F5 0070:073E
COM1 0070:007B 1000_0000_0000_0000 0070:06F5 0070:0721
LPT1 0070:008D 1010_0000_1100_0000 0070:06F5 0070:070C
LPT2 0070:009F 1010_0000_1100_0000 0070:06F5 0070:0713
LPT3 0070:00B8 1010_0000_1100_0000 0070:06F5 0070:071A
COM2 0070:00CA 1000_0000_0000_0000 0070:06F5 0070:0727
COM3 0070:00DC 1000_0000_0000_0000 0070:06F5 0070:072D
COM4 0070:00EE 1000_0000_0000_0000 0070:06F5 0070:0733
Infoplus 1.58à Page 13 - DOS Drive Information
Generated: Fri, Aug 28, 2020 at 3:08:55 pm
LASTDRIVE: E:
Logical drives: A: B: C: D:
Diskette drives: 2
Sectors/track: 9
Bytes/sector: 512
On time (ms): 500
Off time (s): 2.0
Head settle time (ms): 15
Current drive and path: C:\TESTING\INFOPLUS
Drive type is: physical
removable: no door lock: no
JOIN'd: no
SUBST'd: no
Volume label: PRIMARY
Media: fixed disk
Clusters: 37993
Sectors/cluster: 4
Bytes/sector: 512
Total space (bytes): 77809664 ( 75986K)
Free space (bytes): 60835840 ( 59410K)
Infoplus 1.58à Page 14 - BIOS Drive Information
Generated: Fri, Aug 28, 2020 at 3:09:22 pm
BIOS disk parameters:
Unit: 128 129 130 131
Type: fixed disk fixed disk fixed disk fixed disk
Drives: 2 2 2 2
Heads: 6 6 15 15
Cylinders: 819 819 917 917
Sectors/track: 31 31 31 31
Specify bytes: (y for more)
Off time (s):
Bytes/sector:
Sectors/track:
Gap length:
Data length:
Gap length for format:
Fill byte for format:
On time (ms):
Infoplus 1.58à Page 15 - Partition Table Listing
Generated: Fri, Aug 28, 2020 at 3:09:43 pm
Partition table data:
Unit: 128
Partition: 1 2 3 4
Bootable: yes no no no
Starting head: 1 - - -
Starting sector: 1 - - -
Starting cylinder: 0 - - -
System ID: Big DOS-16 - - -
Ending head: 5 - - -
Ending sector: 31 - - -
Ending cylinder: 818 - - -
First partition sector: 31 - - -
Sectors in partition: 152303 - - -
The question here is what happened to the remaining 128 KB of Video RAM? Can any of the video ROM\RAM be moved to the EMS on the BOCA Card using the quarterdeck software? Can the Other items are shown in the Reserved memory be loaded high into the EMS?
