I’m looking for help with restoring a Superbrain II QD. Note that this version of the board has power connecting via a 7-way plug. The issue should be simple to resolve with documentation, but that isn’t quite the case. It’s not that PDFs of the schematics are hard to find. But the resolution used for scanning was inadequate to produce legible documents.
A resistor on the motherboard has blown:
My query is simply “what would be the correct specification for a resistor to replace it?” Two clues remain: a possible red band to the left and a more certain gold band to the right
This is from a layout diagram of the QD motherboard. At the top right, we find that the resistor may be R39, but the layout is not an exact match to the first photo.
In the table of resistor values on the same PDF page, R39 isn’t clear and it seems possible it (and R40, 41 and 42) doesn’t have a specific value.
There’s a schematic for the PSU of the II QD. This time, the relevant part is in the top left of the page, where J2 is illustrated. We can just about make out that the blown resistor connects to pin 3 and has -12 volts:
Lastly, this may be a clue – or it could be a 24 ohm resistor with a completely different function. It’s from an earlier version of the motherboard, the type with the wide ribbon cable carrying all signals. Note the trace to the left has been cut.
Finally, a further request: If anyone has access to clean printed copies of the schematics please scan them and make them available with a link to Dropbox, Google Drive or similar.
With thanks in advance.
