Advice on how to repair vt320 transmit data
munocat
Vancouver WA
I recently got a vt320, it is amber, and I have always wanted an amber. The problem is the serial communication receives, but does not transmits. The cable has been tested on a second vt320 (sadly this is white). I am no electronics expert, but I can solder.
Any advice on where I should look. Dissembling the CRT from the board is very daunting.
Thanks in advance.
Alegend
Israel
Hi,
If disassembling (then somehow fixing, then re-wiring) a PCB in the faulty VT320 is too much trouble, perhaps just do a swap.
I did a VT320 CRT transplant in the past and posted a manual. Maybe if all you want is a working amber VT320, just go ahead and swap the CRTs. No soldering involved.
http://microvax2.org/wp/2017/05/24/vt320-crt-replacement/
Good Luck,
-Alon.
kgober
New Jersey, USA
did you try swapping keyboards with the working VT320? maybe it transmits fine but the keyboard subsystem is faulty?
or did you verify no transmit by sending the VT320 an escape sequence it would be expected to send a response for?
if it's really not transmitting, the usual suspect on other systems is the RS-232 line driver IC. 1488/1489 were very common chip numbers for line driver/receiver chips. if you trace the transmit pin wiring/trace back on the circuit board, the first chip you come to will probably be the line driver. If you can find the VT320 field service manual on-line that should help, but I am travelling currently and don't have time to search myself.
daver2
UK - Worcester
Don't forget that there are also a lot of configurable parameters stored on the terminal itself.
You should check that you have the non working unit setup the same as the working unit.
munocat
Vancouver WA
Hi,
Good Luck,
-Alon.
Thank you, I tried to swap the whole crt unit across. Just got a blank screen.
I check setting, configured the same as the working unit.
I took the logic board out. I see there is a browning around a Transistor.
Have the setting correct?
Use local echo (turn it on in the setup menu)
so you can visualy see if the keybord is working on the screen.
Then check all the setup communications.
Compair with your working display.
Here is a Installation book VT320 a PDF-File
Or throug VT100.net HTM-web
Thanks for link.
Update:
I found someone selling logic boards on eBay. They were asking a lot, more than buying a whole working unit. I contacted them with an offer. It is now in the mail.
Thank you too all. I am tempted in replacing that transistor and seeing if it fixes the fault.
