vwestlife
I take a look at the disk's surface. If it looks smooth and even, then it's worth a try. If it has numerous lines and gouges on the surface, then I hold off on it until a "special projects" session when I'm ready to clean the drive heads if necessary.Is there a way to test the diskettes before putting them in the drive?
Even back in the '80s I had numerous 5¼" floppies get "scratchy"-sounding on me. The disks would still read and write fine, but when spinning, they would make a constant "tsst-tsst-tsst" noise. This happened a LOT with Fuji Film floppies for some reason. Aside from the noise, they never gave me much trouble. So a "scratchy" sound while spinning isn't necessarily bad, but a whine or squeal definitely is!
