AK6DN
I have an issue with moving a RSTS/E v9.6 setup from under SIMH to the real hardware equivalent.
My setup is an 11/44 with full 4MB memory, DZ11, DL11, DEUNA, RX211, and an MSCP disk controller. All the devices are 'exactly' the same between SIMH and the real hardware, except SIMH models an MSCP UDA50, and my 11/44 has an MSCP Emulex UC18 dual SCSI disk/tape interface. I can run the exact same 2.11BSD setup on each, as well as RT-11 and XXDP. RSTS/E however does not behave the same. It dies miserably on the real hardware.
On the real 11/44, after I boot the RSTS/E image on DU1, it runs for a moment, and then immediately fails with the following message:
which repeats endlessly over and over as fast as it can. The emulated disk is an RA81 456MB sized image running on a SCSI disk.
On my SIMH setup, I see quite different behavior. It boots and enters time sharing normally, and SHOW DISK indicates a valid cluster size (16).
I'm looking thru the available v9.0 documentation I have, but not have yet found the above error message and how to decode it (I'm not sure what cluster size it think thinks the disk has, and/or how it computes that).
Any ideas/thoughts appreciated.
Don
Pack cluster size is not 1, 2, 4, 8, 16, 32 or 64.
PC=120324 PS=030344 OV=000006 M5=004000 M6=004200 SP=037716
R0=000026 R1=000000 R2=000000 R3=000000 R4=000002 R5=040030
SP-> 020672 000026 000001 000040 000015 037154
Fatal RSTS/E system initialization error!
Don
sim> boot rq1
RSTS V9.6-11 RSTS96 (DU1) INIT V9.6-11
Today's date? 11-FEB-99
Current time? 19:27
Start timesharing? <Yes>
11-Feb-99 07:41 PM
9 devices disabled
Proceed with system startup? <YES>
Beginning RSTS/E system startup...
11-Feb-99 07:41 PM Installing monitor overlays
11-Feb-99 07:41 PM Mounting disks
11-Feb-99 07:41 PM Assigning logical names
11-Feb-99 07:41 PM Starting error logging
11-Feb-99 07:41 PM Setting system characteristics
11-Feb-99 07:41 PM Installing run-time systems and libraries
11-Feb-99 07:41 PM Setting terminal characteristics
11-Feb-99 07:41 PM Defining system commands
11-Feb-99 07:41 PM Setting printer characteristics
11-Feb-99 07:41 PM Starting spoolers
*** From [1,2] on KB0: at 07:41 PM 11-Feb-99
** RSTS/E is on the air...
RSTS V9.6-11 11-Feb-99 07:41 PM
User: 1,2
Password:
Jobs detached under this account:
Job What Size State Run-time RTS
1 ERRCPY 5K SR 0.5 ...RSX
3 PBS... 25K SL 0.0 ...RSX
Job number to attach to?
Last logged in on 11-Feb-99, 07:41 PM detached.
2 other users are logged in under this account
$ show disk
Disk Structure:
Dsk Open Size Free Clu Err Name Level Comments
DU1 18 891056 832432 93% 16 0 RSTS96 1.2 Pub, DLW
