| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
As long as the controller can read the sector headers, it is possible to do a sector level backup on a PC but it requires software which will communicate directly with the disk subsystem. Here is an example of one such software product:Thanks for writing - I do too as well, but need to make a more low level backup, the file system isn't fat / PC .
Looking to use use one of these; https://www.pdp8online.com/mfm/
thanks,
Jonathan
As recommended above, I too suggest you just buy the Decromancer (aka the Gesswein Beaglebone-based MFM hard drive emulator). I have the most recent version currently being sold on their web site.Anyone in the Can/Ontario area with a BeagleBone MFM Reader/Emulator ?
Looking to backup some old DEC MFM drives before they crapout, as I have no backup...
thanks !
Thanks, this is interesting, I had tried ghost in the past with MFM drives, but found it didn't work out as I'd expected.As long as the controller can read the sector headers, it is possible to do a sector level backup on a PC but it requires software which will communicate directly with the disk subsystem. Here is an example of one such software product:
https://fileforum.com/detail/Active-Partition-Recovery-for-DOS/1345740936/2
I'm not sure it will run on an XT though, you'd probably have better luck using a 16-bit MFM card on a 386 or better
I would honestly buy this in a heartbeat, but it is a bit steep at $249, for what I see as a 1 off job (unless my present drives do fail, then id be looking to write it back to another set of drives here,, ok 2x 1 off job lol , yeah... ).As recommended above, I too suggest you just buy the Decromancer (aka the Gesswein Beaglebone-based MFM hard drive emulator). I have the most recent version currently being sold on their web site.
It is very easy to image virtually any old MFM drive with this device. The instructions provided are a bit cryptic - if you need any help, just ask here.
The advantage of backing up to your own drive emulator is that when the existing hard drive fails you can just plug the emulator, select the drive image file you want it to use, and your system will be back up and running right away. You don't necessarily need to buy enough emulators to replace all your old MFM drives right away - for now you can just buy one, and image all your drives to the same emulator since it has enough built in flash RAM to hold the image file for each of several different hard drives.
This is a very good tip, I will make sure to disable the write gate signal before trying anything.It is an incredibly BAD idea to attempt to image a MFM hard disk with a PC controller that has a BIOS rom installed unless you know for a fact that
the disk was written with the same model controller. I do not know of anyone who has successfully done this. I do know people destroying the first
tracks of their disks in their attempts when the controller decides to overwrite data there. Unlike floppies, there are many different on-disk sector formats
on hard disks. Dave's table of them in the reader source code gives you an idea of how many differing ones there are.
A reminder that the write gate signal should be physically disconnected on the cable (or use the write protect jumper on the MFM emulator) when
attempting to image an MFM drive.
yeah, the original controller iirc was built from discrete logic chips, and I wouldn't know which modern asic would perform the same as that.They do write differently. As Al pointed out, there are different sectoring standards. You will have the best luck if you know which brand of ASIC was on the original controller and use a card with the same one.
Geometry is specific to the drive itself and interleave isn't really relevant here, but if the controller can't read the sector headers from the existing format it will not be able to do anything at all with the drive
I mean it is an emulator, so if you did have a drive failure, you could use it until you found replacement spinning drives, if you prefer them.(unless my present drives do fail, then id be looking to write it back to another set of drives here,, ok 2x 1 off job lol , yeah... ).
Also a big chunk of the price is the beaglebone and I think you can buy bare boards for the main pcb, so there are probably ways to save some costs. I chose to get the complete tested solution because I have no idea what I'm doing and I didn't want to always be questioning if my assembly skills were the cause of any problem I might have had.
Yes I sell bare boards which saves some* www.pdp8online.com/mfm. Last i looked ebay had cheap beaglebone greens. I have one green left that I offer for $25 less for assembled. It doesn't have fix for intermittent wired ethernet issue.Also a big chunk of the price is the beaglebone and I think you can buy bare boards for the main pcb,
The cost of shipping from the US to Canada is the problem. It seems almost everything costs at least $25 to ship, so if you need to shop from several different US-based suppliers to acquire all the required parts the total cost quickly adds up. Further adding to the cost for someone located in Canada are the currently lousy $ exchange rate, and the possibility of also having to pay the post office handling fee and "goods and services tax" on each item brought in. I had really wanted to buy the parts from https://www.pdp8online.com/mfm/ and build my own, but in my situation after adding everything up there was little cost saving vs buying the complete tested unit sold by Decromancer.Yes I sell bare boards which saves some* www.pdp8online.com/mfm. Last i looked ebay had cheap beaglebone greens. I have one green left that I offer for $25 less for assembled. It doesn't have fix for intermittent wired ethernet issue.
* you would need to see if cheaper where you are.
For the moment, I do enjoy having the old physical drives going, they are going to fail one day at some point, so I may as well use them while they're working, and then be prepared to fall back to something else if needed.I mean it is an emulator, so if you did have a drive failure, you could use it until you found replacement spinning drives, if you prefer them.
Thanks for you and the community efforts in putting stuff like this together!Yes I sell bare boards which saves some* www.pdp8online.com/mfm. Last i looked ebay had cheap beaglebone greens. I have one green left that I offer for $25 less for assembled. It doesn't have fix for intermittent wired ethernet issue.
