You wonder, given the seven empty slots, where the hard-disk controller is. Columbia chose to implement a couple of extra parallel ports on the motherboard and run a ribbon cable up to a large controller board that sits above the hard disk and floppy drives. The controller is actually a Z80-based single board computer with its own 64K of memory, but it's been programmed to exactly emulate the IBM disk controller.
So complete is this emulation that we were able to take a copy of PC-DOS 2.1 and do a front-to-back installation of DOS onto the hard disk. We wondered what sort of schizophrenia our brain transplant would touch off, but the Columbia was firmly convinced that it was a PC-XT and did not stray from that illusion during the course of our testing.
The Columbia executed our read and write test in 1 minute, 20 seconds and 2 minutes, 35 seconds, respectively, on floppy disk, and cranked out a very respectable 9 seconds and 28 seconds respectively, on the hard disk. Columbia's historic expertise in 8-bit systems was obviously working for it when it designed the disk controller.
