Are you sure you configured the bios properly before you flashed the chip,
Also i'd use the Latest R591 available from Here, Rather than the very old official releases that were on the old google code site.
My configuration is shown at [here].It works fine, but I didn't find a way boot from it if the MFM disk is present. I'm working with the default switch settings, "Enable ROM" = ON.
It appears the Xt-IDE ROM text, but I didn't find a way to boot from the XT-IDE. I pressed F8, no way.
Are you aware that this requires two changes:BTW the Speed mode (Chuck's mod) doesn't work for me. Currenty I'm using an 8088 XT Clone.
For background, refer to [here].The 2nd board I assembled was returning ROM ERR. I thought it was due to the R591 release. I flashed the rom again with the 1.5 stable rel: again ROM ERR
And now also the previously working board is returning ROM ERR.
What's could it be?
... I then programmed the flash rom with the latest beta firmware (2.00 beta 3 => ide_xt.bin) using my eprom programmer....
Using XTIDECFG.COM to flash the EEPROM will automatically calculate and use the required checksum.... Note: I flashed the chip with an eprom programmer before to insert it in its socket. ...
I have two negative reports about coexistence with MFM BIOS-es. One controller was a DTC-51xx. The symptom was as you described: both controllers work single well but does not boot together. Jumper setting was correct: 320/C800 for MFM controller and 300/D000 for XT IDE.
1. Change of the two jumpers on the XT-IDE Rev 3 card; and
2. Reconfigure the XTIDE Universal BIOS
BTW Are 27512 pin to pin compatible with 27256 ?
The Compatibility/Hi-Speed jumpers change which register map is used (hardware).I knew about the two jumpers, but I didn't know about reconfiguring the BIOS. Maybe it was explained in a previous post? I read the whole thread, but maybe I miss it...
You are using version 1.1.5 of the XTIDE Universal BIOS. It does not 'know' about hi-speed mode.Can you explain how to do?
Apparently people are having trouble finding the XUB 1.1.5 ZIP file, so I've uploaded it here:
ftp://filedump.glitchwrks.com/xt_ide/bios/xub_1.1.5.zip (FTP)
http://filedump.glitchwrks.com/xt_ide/bios/xub_1.1.5.zip (HTTP)
More technical information about that is at [here].
To use hi-speed mode, you would either have to:
* Upgrade to a 2.x.x version of the XTIDE Universal BIOS; or
* Find the hacked 1.x.x version of the XTIDE Universal BIOS (hacked for hi-speed mode).
Why would anyone intentionally run the older version?
