AmigaJules
I recently acquired a pretty loaded 6300.
It has what I believe is a memory board (in addition to 640K on the motherboard) {EDIT} My bad: 640K total with the fully populated memory board. 8087. VDC 750 EGA card. Write-right bus enhancer. 20MB seagate ST-225. 319 display. Mouse. Boxed copy of Windows 2.0. And the full set of manuals, software & documentation.
I purchased it from the original owner who had stored it in its proper orientation.
The battery had leaked onto the case, not the board. There was a very small amount of corrosion around it. I've clipped the battery and cleaned up the corrosion with white vinegar followed by distilled water & isopropyl.
When I turn it on, I get blinking keyboard LEDs but nothing on the display, no beep, no post. I believe I've read that the 6300 does not require a battery for POST, only to maintain clock/calendar.
The PSU voltage to the motherboard is 5.08v, but the CRT voltage measured at the J7 connector on the mono display card is 16.25v. The PSU has the display voltage marked as 12v - is this normal if there's no load from a mono display? Or could it possibly point to a PSU problem? {EDIT} - I'm reviewing the service manual and it looks like the CRT voltage is 15v not 12, so 16.25 is within the 10% tolerances...
Any suggested troubleshooting steps from 6300 experts?
While I wait for replies, I'm going to disconnect HD & controller, remove VGA & RAM card and try to get it down to a minimum config to rule out an issue from one of the cards.
I've pushed all of the socketed IC's into their sockets, but may also remove and reinsert them.
Thanks for any insight!
